It fits! Had to swap the pulley over off the old 120a one and open out the washers as the shaft is a bit longer, but it was literally a direct bolt on and the pulleys line up perfect.
The connector is different, but if you pull the green bit out of the connector it pushes on. Will change it later when i get the connector.
