Ive just lowered my t4 60mm, how can i get a smoother ride and lower the rear more? it still sits higher than the front.:confused:
You're probably hitting the bumpstops at -60mm? Ideally shorter sports shocks will help and possibly chopped bumpstops? Gaz shocks or similar? Can you raise the front a bit to at least level it off, the back will obviously dip the more you raise the front. The front must be in the weeds if the back's still higher at -60mm!
