As it says if i fit shortend shocks does this have any impact on the set up or ride or wil i be better of with the standard shocks on my 40mm dop on kws T:
If your springs aren't becoming loose or dislocated when you jack your van up, I personaly wouldn't bother with shortened units. I would look for a good quality heavy duty gas charged set.
I've had 4 different sets of shockers on my van last year trying to get the thing to ride how I like. From standard to now Projektzwo (Bilstein B6s). I've found the rear end never seems to change much in ride or control from make to make with what I fitted, but the front has varied quite a bit.
can you elaborate on your current set up, very interested in what you have found, regards
I'll try!LOL:
My opinions were;
The rear end has never changed in either comfort/harshness (rapid movement) or spring/body control (long movement), with any of the different shock absorbers I've fitted. Although I think with say 400+ kg in the back, more of a differences in spring/body control might be noticeable.
The front has shown more of a diffence between different makes regardless of fuel levels.
Used standard (what came with the van. Green, VW?) comfort/harshness was soft with spring/body control fair.
Shortened yellow (£120 a set type) comfort/harshness medium-firm, spring/body control poor. :mw is my memory of those!
Sachs/Boge comfort/harshness medium, spring/body control good.
Bilstein B6s comfort/harshness firm but nice with spring/body control very good.
As said many times before "You get what you pay for". T:
