Hi. as above, I am having trouble locating a replacement auxiliary water pump as the ones online listed as compatible show the pump with a 3 pin plug connection located to the pump side where as mine has a 2 pin connector mounted at the top of the pump. The wiring on the van looks original but the lack of compatible pumps showing up is confusing.
Has anyone here experience of changing the pump on this same engine type (caac) and knows if the connection was the 2 pin type? Thanks.
