1 - 12 of 12 Posts
The near side rear fog light does not light up. I've checked it and there is a bulb in. There are no failed bulb warnings on the dash. The van is only a few weeks old:*
Seem to remember reading somewhere that it was just a cost cutting measure, and the wire IS in the loom somewhere, just needs extending/ connecting and bulb fitting:)
There is a bulb in the light cluster :confused:
ISS said:
All three should work T:
All 3 :eek: where's the third one:*
the regulations only require an ofside rear fog light.vw on all models only connect the offside foglight.
Yup - that's the rule in UK.
Previously; Trikemania
The bulb is there, the lamp is complete to the plug,
but no pin at the lamp nor wire from lamp to loom,
sure would appreciate knowing what/where that loom wire is?
me LHD, need that soon
as a bye the way, if two fitted, do they have to match?:*
VW T5.1 2013 - can I just run a cable from the offside light to the nearside light or will this confuse the system?
1 - 12 of 12 Posts
