Side door bottom runner drain hole?
15K views 24 replies 8 participants last post by  bournrich
In your pictures the drain hole is likely hidden by the lower door runner arm, pull the door fwd an inch.
The drain is in the vertical face of the slot below where the lower door runners sit.
Crawl under van just in front of the rear trailing arm mount (big chunk of metal where you Jack van up).
The drain hole is forward of this about half an inch above the cill edge.
Push some rubber pipe inside the door seal to force it to balloon out, it should then fill the gap...
If you haven't a drain hole drill one towards the rear of the channel in the vertical face on the inside of the van.
Hth
c pillar full of water is likely rusted out inner wheel arch, check for rot in the lip of the wheel arch...
the door runner isnt open to the c pillar
if your inner wheel arch is shot id get new metal in before you loose the base of the c-pillar to tin worm
