Hi all,
I have noticed on the van that when I switch on the headlights I cannot get just side lights but headlights only that work fine with the high and low beam. for example I put the switch into what should be side lights only the little light on the switch lights up and the rear lights are ok but NO side lights in the headlights but when I put the switch into the headlight poistion the little light on the swtich goes out, the headlights are on with the headlamp side lamps and headlights work fine with the main beam and dip, the rear lamps once again ok.
Any ideas and suggestions please?
Thanks all
Chrisw
