1 - 10 of 10 Posts
Hello everyone,
With the van running sweet after my recent fiasco, it's time to get a side window fitted.
I'd like to get a sliding privacy glass window.
I've searched and read a huge amount of threads (still quite possible I've missed something), but still can't seem to find any recommendations for anywhere in London where I could get this done.
I just refuse to believe there is no where in the capital of England that doesn't do this.
I know of TidyTransporters (now TidyCampers for the window fitting), but they are a little too far.
Someone mentioned middlesexmotorcaravans.co.uk, but they want £425ish which seems to be around £125 more than most other people.
Any help would be greatly appreciated! T:
Many thanks people,
S
Thanks for the reply Meatball. T4world is still a good hour and 20mins drive.
I know it isn't really that far, but I'm still sure there must be something in London.
I'll definitely keep James in mine, in the mean time the quest continues.
Just in case it helps Stevie, I was surprised how easy it was to fit a van side sliding window. I found a type I could pop rivet in place, so it was just a case of cutting the hole (jigsaw), squidging sealant on, rivetting in place and pressing a covering strip over the pop rivet channel. Window silvering film did the privacy trick.
That was on a Merc van, not a T4 - it took me 2 hours. That's 10 years ago and it's not leaked in the slightest + loads more secure than the normal fit windows. The only thing I'd change would be to properly masking tape the area before cutting.. my jigsaw base scratched the paint in a couple of places but that was no drama.
oh, the sunroof was the same too. was really simple. just google camper van windows probably.
Yeah, this is an idea I've been mulling over, but to be honest, for about £100 extra I'm willing to let someone else do it. Much less time and cursing on my part!
But saying that, if I can't find anyone really near, I might end up doing it :)
Look for a Caravelle sliding window - they bolt in and are made for the job - they often come up on ebay and you can easily tint them yourself before fitting them........
Is that what you have on your van?
And as a side question, what method did you use to cut the panel out?
Cheers,
S
Cheers,
S
My current van is a Caravelle but my previous had a Caravelle window which I fitted myself. To cut the corner radii I used a hole cutter intended for fitting recessed ceiling lights then joined them up with an angle grinder - there's a 'how to' on here somewhere.........
1 - 10 of 10 Posts
