I'm trying to get as pro a finish as I can on the interior of the two side windows and I'm after a template to make a wooden surround to carpet for the windows? Any ideas?
Hi I did mine the same way the only difference is I used wood laminate floor under lay (the white foam stuff) this makes the job a bit easier as you can see through it making it easier to see the correct line to cut on and also it cuts easier with a stanley knife. If you buy a full roll you can use it to template other areas of the van.T:T:
hey bud i used a company called NER seals 73 anthea drive, huntington, york yo319db tel 07984185900. they do rubber seals. if you contaxct him he will send you some samples through the post free of charge, try them and the one that fits yours you can order. finished the job nicwe and neat me thinks
