I want to put side windows in my van. Do you need different glasses for each side.
My local VW dealer has supplied two of the same number:confused:
Hello, if its a T4 the glasses are the same, its the ceramic band (black band) thats different, it is wider on the sliding door.
If its a T5, they are handed, they will fit either side, but one will have the Kite mark upside down- so better to get the left and right.
Hope this helps
Hope this helps
just checked your profile and you have a t4 so what firstglass says,the black band is the difference but windows are same size,
my window part nos were
703845301AA
703845301T
Thanks Guys,
If I fit these they will fit, but why is there a difference in black bands?
its wider on the side door as the metal is wider there,if its 2 side door ones you have and you fit it to the opposite side you will see the black band as it wont be hidden by the metal,
Cheers, I get it now.
Must get them fitted now.
