Hello
I am about to start deadening and lining my van, using Silent Coat 2mm deadening, before Dodo Thermo Liner 7mm. I am advised the Thermo Liner, is an alternative equivalent to say, using 10mm of glass wool.
I am brand new to this and have got a bit confused with researching and reading so many posts, about different approaches to using various combinations of layers and lining types. So am asking for help.
Can I please ask if it is recommended, that I use the 2mm deadening, followed by 7mm thermo liner, then just put the carpet lined ply panels directly on top of that? Or do I need to fill any void areas, being that the two types of deadening and insulation chosen, won't bulk out to meet the ply panel where there are recesses (single panel areas). I am not sure if I need to plug voids between ply and foil backed lining, with wadding/something absorbent or not.
Thanks in advance.
Thanks in advance.
