I have had a search but I cannot seem to find anything covering what I'm asking so wondering if anyone could help? I have a 1996 T4. Its nothing too difficult and I'm sure the question has most likely been asked before and covered too. Anyhow, I am wanting to replace my twin passenger seat with a single passenger seat.
I have two Audi TT seats that I want to fit but I'm wondering if this would be straight forward. I would imagine that the drivers seat would pretty much be out and in. The passenger side I'm not too sure this would be the case.
Would anybody know if when I remove the double seat, whether bolt holes for a single seat base would be there? Also is there anything else that needs to be known when doing this?
Thanks in advance T:
If its the same as my 2000 T4 just remove the double bench (4 bolts) and bolt in a single seat base - Easy!T:
How difficult it is to fit the seats to the bases is a different matter, but normally a piece of hefty flat bar drilled correctly and bolted on does the job.:*
Thanks for the reply. I was hoping it was as easy as just out and in T:
Fitting the seats to the bases should hopefully be straight forward. I saw a lot of people say TT seats are pretty easy to fit.
Thank you. A:
