hi folks cant find the answer tomy question so any help advise would be gratefull.
im just about finished with the fitting out of my van i have sink with a new tap fitted with 12v microswithch, i also have a 12v pump that runs in line my question is if i want to use a 10l container how do i get pipe into tank but make it still water tight to drive with it full?
just thought their would be something so its always ready to use rather than messing about when you need it.
if you get an inline connector for the diameter tube you are using drill a hole the exact same size in the lid then sikaflex it inplace and leave for 24hrs. one simple air tight container.
nice and simple al try that this week, would you have it with a bit tubing to bottom of container then tubing on outside of container to pump
thanks for your help
cheers spanner monkey hadnt thought about that.
ordered 2 10l tanks today so job for the weekend
