Evening peeps....went to open my sliding door this evening and it won't! I have taken door panel off and the wire has come loose from the rear of the door? ( if you on the inside looking at it it on the left ) I can pull the wire through as it isn't attached to anything anymore. My question therefore is; is there an easy solution to my liccle problem or is it a major undertaking? From what I can see there is no room to get fingers in.
I'm **** at this sort of struff so go easy on me.
Creeriver
Creeriver
