Hi All,
Apologies I know this is a topic that is covered often but my sliding door has dropped significantly on the left side and the top runner is popping out. I have tried lifting and re-setting the bolts on the lower right hand side but it has not corrected the problem. As you can see the paintwork on the lower right hand side is now starting to chip off which I don't want. Do you think the lower roller could be bent and this might be the problem, I have taken a picture for reference.
183045
183046
183047
Following. Similar issue with mine, though I've not yet tried putting the washers in as you have. I recently replaced the bottom roller and top guide but I'm wondering if a different make of roller would have had the door sit higher. I've not looked through the forum yet but I'm sure others must have had similar issues.
