I fitted a bodykit with wider arches and wheels that come out to a point on the spoke to a t4 a while ago, I got past the sliding door spacing issue by using penny washers. You need to take of the roller guide (long silver bit) and put 1 washer on the stud cosest to the door 2 on the second, 3 on the third and 4 on the fourth if you can. Doing this spaced it enough to do what i needed and is probably the cheapest option. Also for it standing up to the test of time... It aint fallen off yet!
