hello
i was thinking of trying to get a second hand sliding door as mine will take some work to get it straight i want to replace a caravelle windowed door but be easyier to source a van door so the QUESTION is when i look at my van sliding door from the inside there is the lip to bolt the window in but from outside there is no seam in the panel is it a different skin on the outside can you cut the window out with a nibbler ???
does any of this make sence ???
hmmmm!!
