Hi all, i`v just brought this side door and window in it and need to remove the window there is a slight bit of rust under the rubber trim, before i swap it over i would like to sort it out so does anyone know how these windows are put in...is it clued or screwed..
This looks like a window that i have sitting in my garage. If you pull the plastic trim out from the frame, there are pop rivits behind there. just drill off the heads and it falls out. The window i have came out of an LGV mini bus but i dont think they are BL items, just an after market window. Hope this helps. T:
Sorry do you mean remove the rubber trim..I: if so what just pull it out or what.
