Hi
I’m looking for any tips advice on my 2.4aab deisel 1998 t4
It all works great cruises no problem on flat but as soon as I hit an incline it drops speed with me then having to drop gears.
I’ve read other posts suggesting pump timing maf sensors etc.
any tips advice would be great.
on another note. It gives me nearly 700 miles to a full tank of fuel.
brilliant on the mpg. Should I accept the gear dropping just in case I change something that gives me less mpg or is this usual mpg for these Vans.
thanks.
Hi
thanks.
theres no 'maf' sensor on the 2.4, the 2.4 is a 'dumb' mecanically controlled 'IDI' engine:(
From
when was it last serviced?
air & fuel filters are cheaply replaced & make a diference on these, also whats the cam / injection pump timing like as this really makes the 2.4 wake up (y)
if thats all good it's worth checking that the exhaust is not blocked (silencer baffles clogged or collapsed) - easily tested by loosening the exhaust joints & test-driving...
BUT remember, the 2.4 is a slug, will get you there slowly (68 hp??) not a modern powerfull engine:rolleyes:
Rich.
Rich.
From
Thanks rich.
serviced last month. Not sure about the timing. Is this easily checked. Keen to try ?
Rich.
Hi
thanks.
Hi Scottclimb,
I have a '99 T4 Auto-Sleeper, previously I had a 2009 T5 with 145 BHP. As the T4 pushes out a lot less BHP than the T5 did, I find it a bit snail like. So not knowing whether it was me or after having the T5, when it was in for service I got them to take it out but they reckoned for the less power it has plus it weighs 200 kgs more the performance is about right. Not sure if this helps but it might give you some thoughts.
