1 - 12 of 12 Posts
i have a plan.
I need to replace my current battery, I'd also like to install a leisure battery,
HERE'S A DIAGRAM OF THE PLAN
for the starter battery i would like to use the absolute smallest bare minimum size for reliable, everyday van use - it just needs to get her started, that's it.
can anyone recommend one?
B
someone on here makes twin battery trays which fit exactly where your existing battery is just now,allows you to fit leisure battery alongside existing battery without changing size etc,
cool - I'll def need one of those,
still not sure what spec battery to go for though, I've found a tech article on deep cycle batteries but i don't think this answers my question.
Since Ive got to buy a new starter battery anyway i would like to get a really good quality one but no bigger than absolutely necessary.
Discussion Starter · #8 ·
I'd like the smallest batteries so as not to put too much unnecessary weight over one corner of the vehicle, it literally needs to start the engine - thats it - then the split charge system is going to prioritise recharging that before charging the leisure battery - which isn't going to be huge either.
I'd like to rewire the stereo and rear cabin lights so that they run from the leisure battery, cos thats all i really use when camping, that and maybe a phone charger - then i know i can run them till they're done without running the risk of not being able to start the engine - also i think the reason i need to replace my current battery is because i have flattened it whilst camping - regular non-deep-cycle car batteries don't like being flattened (right?)
Obviously the size of the leisure battery will just dictate how much radio and light useage i get but i expect the starter motor battery has some fundamental necessities....
....so....
....can anyone recommend a small, high quality, reliable battery that meets the vans minimum needs?
Discussion Starter · #12 ·
thanks for the help, Ive put in an 096 Varta battery - cost £65 and I've ordered about £100 worth of bits from Raw Components inc the basic intelligent split charge system
I reckon I'll get the Lesh battery that Spock suggested and I'll try and wing it with my dad's welding kit as far as a battery tray goes. I'll update with my sucess/failure. B
1 - 12 of 12 Posts
