Hi
My 7H T5 2.5TDI 174HK just started acting up.
It misses power when accelerating, and it is more noisy when stepping on it. Also it smells of petrol when stationary at red lights.
I have tried to look for obvious leaks in intake or exhaust - but can see nothing.
Anybody has any good ideas where to start?
I got this from the auto scan:
Friday,12,August,2016,17:09:10:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WV1ZZZ7HZ6H046057 License Plate:
Mileage: 166660km-103557mi Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H046057 Mileage: 166660km/103557miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BD HW: 028 101 183 5
Component: R5 2,5L EDC G000AG 7001
Revision: 12345678 Serial number: VWZ7Z0E2605840
Coding: 0001075
Shop #: WSC 02771 785 00200
VCID: 53A599C7F1009386791-50E6
1 Fault Found:
18045 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 207.4 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00001111
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No: 09K 927 750 J
Component: AQ 250 6F 0621
Coding: 0000008
Shop #: WSC 02756 785 00200
VCID: 3C77D27B7C9E7CFE88B-5000
No fault code found.
Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
Part No: 7H0 907 379 G
Component: ASR FRONT MK25 0103
Coding: 0007205
VCID: 3979CB6F73AC49D693D-5000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H0 820 045 AM
Component: CLIMA/AC 0303
Shop #: WSC 00000 000 00000
VCID: 70EF364B6056C89E643-5000
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 Q
Component: BORDNETZ SGVER 1.0 1901
Coding: 0000103
Shop #: WSC 02737 785 00200
VCID: 408FA68B1076181ED43-5000
3 Faults Found:
00077 - Windshield Wiper Stop Switch (F229)
004 - No Signal/Communication
00991 - Interior Lights
012 - Electrical Fault in Circuit - Intermittent
01336 - Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0008
Coding: 13123
Shop #: WSC 02756
VCID: 224B0C03AE3A2A0EA27-5000
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 851 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 01112
Shop #: WSC 00737
VCID: 2E53E833EAE29E6E36F-5000
WV1ZZZ7HZ6H046057 VWZ7Z0E2605840
1 Fault Found:
01322 - Control Module for Multi-Function Unit (MFA) (J501)
49-10 - No Communications - Intermittent
Address 18: Aux. Heat Labels: None
Part No: 7H0 819 008 M
Component: Standheizung 0208
VCID: 3663C05342B2A6AE7EF-5000
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02737
VCID: F0EFB64BB056489EE43-5000
1 Fault Found:
Address 45: Inter. Monitor Labels: 7Hx-951-171.lbl
Part No: 7H0 951 171
Component: Innenraumueberw. 2815
Coding: 0000021
VCID: E7DDDD17D5988F26B59-5000
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C2B Komfortgerát 0004
Coding: 00073
Shop #: WSC 02756
VCID: 326BFC43FEDABA8E527-4A9C
Subsystem 1 - Part No: 7H1959801A
Component: Tõrsteuer.FS KLO 0203
Subsystem 2 - Part No: 7H1959802A
Component: Tõrsteuer.BF KLO 0203
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 M
Component: DACHDISPLAY 0539
Revision: 00800539 Serial number: 2009266.07
VCID: 4189A38F1B7C1116DBD-5000
End ---------------------------------------------------------------------
Best regards
