hi i have 2003 t4 2.5 tdi ,it runs very well ,does not smoke attall does not use any oil ,no problems attall ,BUT it all ways seem to smell of oil or somethink like that is this normal can anyone help .thanks:*
How's the gaiter over the gear stick? Ripped, loose?
Could be a cracked exhaust manifold, quite a common failure on early 2.5's.
Evidently it's a nightmare to diagnose due to it's location.
Sorry, partially ignore last post, I thought i was on the T5 section!
It's still worth checking for exhaust leaks around the manifold, turbo and down pipe flexi joint.
Also oil leaks onto the above parts.
