Cant find anything definitive anywhere on fitting an oven in my T5 so hopeful of some specific info. I have a LWB and am fitting a run on the off-side. Starts with the fridge then the oven. I'm planning to cut out the ply panel thats currently carpeted directly behind the oven position to increase the gap behind, then I was going to glue a spacer to form a border around this cutout to the rear of the panel then line this recess with heat proof insulation foil. The foil is supplied in lots of sizes so could extend the foil from the rear to envelope the oven within its cabinet.
Does this seem like a reasonable thing to do or can anyone confirm if the built in insulation of the oven will suffice as long as I maintain an airflow gap?
