Now available Smev Combi Units, relevent pipe work and complete install packages!
Smev Series 8800 - 1 Burner Combi with RH/LH Sink.
One burner combination unit (with ignition), sink bowl. Colour : Inox. Includes removemable drainer that fits over hob and integral fold down tap.
Dimensions: Depth: 421 mm, Width: 525 mm.
£180 + PnP
Smev Series 8322 Combination Sink/2 Burner Hob.
This combination hob and sink combination unit is fitted with fold down tap, single black glass lid. Electronic Ignition. Flush fitting. Colour : Inox. Dimensions: Length : 680 mm, Depth: 440 mm.
£250 + PnP
Smev Series 9123 with RH/LH Sink.
One piece combination sink/hob. This model is comes with 2 burner hob and right hand sink. Fits into the worksurface. Has two glass lids that work independently. Piezo ignition. Colour: Inox. Includes fold-down tap. Dimensions: Width: 900 mm, Depth: 375 mm.
£280 + PnP
Smev Install kit: Waste pipe, fresh water pipe, LPG gas pipe, pump, tank
£50 + PnP
Waste water pipe suit SMEV £2.50 per metre + PnP
LPG gas hose suit SMEV £2.50 per metre + PnP
Fresh water pipe suit SMEV £2.00 per metre + PnP
