Will shortly buy a smev sink (probably going for 8006 model 420x440x145mm). There's load of websites out there selling them.
And suppose most will sell just the sink by itself with none of the extra bits.
Just wondering what else i need to buy:
Waste fitting - angled or straight?
10mm hose?
What time of pump? Only using cold water so just a straight forward one needed.
Anything else?
Will it come with the tap?
And if anyone can recommend any sellers, that'll be great
Hi, I have just fitted a sink.
I just trawled the net and found the cheapest price. I was supplied a waste with mine (a dometic with a lid). Generally they wont come with a tap.
Choice of straight or angled waste will depend on which is most convenient for your proposed arrangement for the plumbing. I used a submersible pump, as this seemed the simplest and most space saving option. You do have to find a container with a wide cap (DIN96 I think) which can be a bit of an issue, depending on space available to fit the container.
I bought two similar containers and fitted them alongside each other under the sink, one for fresh and one for waste.
Very pleased with the final arangement.
Good luck
Andy
