Finally got the Bus into the garage for a fix, the problem turned out to be the Aircon intake sensor, located behind the scuttle where the wiper mechanism lives, had totally burnt out and melted causing one of the Aircon fuses to blow which also led to both radiator fans running full time (default mode apparently). What was slightly unhelpful was the fault memory only showed a blown fuse and mentioned nothing about the melted sensor so old fashioned wiring diagrams had to be used to trace the fault back from the fuse. :)
Peace of mind now the problems been found T:
