Hi, just wondering if anyone could help, i started my 2000 1.9td earlier and had a small amount of smoke earlier come from the stering column around the indicator stalk area, i stoped it imidiatly and removed the cowling then started it again and got a very small amount and then it cleared, ive tryed quight a few times since and its been fine and all my electrics work fine, the only thing i have ocasionaly had about once a month is the van just turn over and not start like the imobiliser hasnt cleared but then i just turn the ignition off and on again and it starts! Has anybody got any ideas? cheers Greg
ive also hd this problem in the past. turn the ignition on and had a little bit of smoke amost like steam/mist doesnt smell like smoke....but everything works :* hasnt done it since and never did find out
do a search for this fault and theres a video on here i think it will need a new stalk to sort it out ?
dirty indicator contacts might spark the oily dust and cobwebs ? I've known it happen before,
OR
an accessory wire might be chaffing & shorting against the column
where abouts was the smoke - high up near s/wheel, or lower down near wiiung loom?
whip the cowling off and give it a good dust / blow out
Hi, thanx very much for the reply, ive got the cowling of and it was coming from the wiper stak area, havent had any smoke since, have tryed giving it a blow out but havent got somewhere with a air line to use yet, du recon i should just get some new stalks? cheers Greg
