Hi I have a 1995 T4 1.9d non turbo, I bought her about a month ago. When I bought her she had some smoke on initial start up but this would clear on the way back from the MOT she shredded the aux belt which in turn knocked the timing out. Any whey new belts fitted and retimed and she starts great and sounds fine, however we have just been on a 1000 mile round trip to Newquey and we noticed heavy black/blue smoke under load ie up the many hills they have down there. Checked the oil and she had used 1L of oil on the way down and a further 2L on the remaining 650 miles back to home.
My question is this, I believe is could be a number of things, rings, valve seals or bent valve. I wanted to try and rule out rings by doing a compression test but if I have a bent valve (due to the timing slip) will a compression test still work?
Or am I looking in the wrong place completely ie timing still off?
Any help is appreciated.
