Just bought a cheap 12v 1.5W solar charger. I just wanted to keep the van battery charged up while it's going to parked up for a fortnight. However I just put a volt meter over the chrger and it seems to be putting out 21v is this right ? I figured it would be about 14v but 21 seems a lot more.
That's with no load, so as soon as you connect a battery it will pull it down. You should really use a solar regulator but if it's only 1.5W then it won't make a difference but make sure it has a diode to stop the battery flowing into the then solar panel.
Thanks Blaster, It was purchased from Maplins and says it cannot drain the battery by back feeding...or words to that effect.
I was hoping to see my built in volt meter go up a little with this plugged in but maybe it puts out so little the digital v meter won't show anything. Maybe I'll hook up my proper volt meter whne I get home....then again it's dark then !
Thanks again
Full of Cr*p....
It's actually got no chance of CHARGING a battery bigger than about 5Ah!
1.5 W is probably not even as much as your radio, normal van electrics and the standard discharge rate of your battery will be using 24/7.
A 10 watt panel would be more suitable if you only want it to maintain your battery.
Saying that, my van spent 6 weeks buried under snow, and still started with no problems.
I have one of those 12W breifcase type panels which I think comes with a regulator/contoller. Maybe I'll just use that instead. Makes me wonder why I bothered buying the 1.5W panel ....Doh !
