Hello,
I have recently fitted two flexible 80w panels to my sca roof, I hooked them to my regulator yesterday and connected a battery to test it all,
The panels output a fairly consistent 20v fluctuating slightly and slowly but the output from the regulator to the battery was jumping around from 13-15v very quickly I assume this is ok/normal?
I am concerned it will damage the batteries due to the fluctuation.
Any advise much appreciated
Mark
this is the regulator specs -
Parameters CQ1220
Rated Voltage(VDC) 12
Rated Current(A) 20
Max. input Voltage(V) 25
Over-Charge (V) Protection 14.4 ±0.1
Resume 13.3 ±0.1
Over-Discharge(V) Cut-off 11.1 ±0.1
Resume 13.2 ±0.1
Over-Loaded Cut-off 16.5
Resume 15.0
Voltage Drop(V) Between input and batteries 0.3
Between batteries and load <5
No Load Current Draw(mA) <10
Ambient Temperature
  -10℃~55℃
It is unusual to see such a great variation unless you were being swept over by clouds. What state of charge was the battery in?
