I've just bought a T5 with a 20'' stormer spare in the back. Trouble is, the spare doesn't fit under the van. Don't really want it in the van!! Can the original spare wheel storage be modified?:
Dont fit no RR Stormer wheel under your Van:no Save it! T:
In order to fit RR wheels, there might have been made alterationt to your hub. Have that qlarified.
If you absolutely need a alloy spare wheel, get a narrower one off a Discovery3. They have the same stud pattern & higher LII:
Many do cope with the "spare wheel in a tin" allthough that is a matter of choice
I take it you dont have a 4-Motion?
Were you using the original wheelnuts or the ones for the RR alloys? They are different! As I run RR alloys but use an original steel for a spare I carry a set of original wheelbolts, the wheel brace to fit and some mole grips to remove the studs for the RR nuts. Oh and don't forget to remove the spigot ring as well.I tried fitting the original spare but the bolt threads that are part of the brake drum aren't long enough. Even with tapered wheel nuts, the wheel would still be unsafe. Would you recommend trying to fit the new alloy underneath and modify the olding bracket?
