Hi all I am new to the forum. I have a 2002 t4 2.5tdi and the pointers for the speedo and rev counter dont light up. The dials all light up in blue and everything else on the dash works fine (fuel guage, temp guage etc) but this is driving me and my other half nuts ...........as soon as it gets dark I can't see what speed Im doing. Dont know if its connected in any way but heater controls and electric window switches also dont light up. We have had the instrument panel out and checked all the fuses. Any suggestions or help very gratefully received.
Jacqui :(
faulty instrument cluster - this is a relatively common fault for these. What part number is the cluster? (should start with: 7DX XXX XXXx)
Hi I have this problem too.
Mine is a 2000 plate able
If I can get the code off the clocks would you be able to help me penbryn?
I have had the clocks apart but couldn't see any bulbs so I am guessing it has very small leds !
and me too... i just put 2 mini LEDs in the top of the cluster housing and wired them via a 10amp fuse to the light switch
