Hi Guys,
I need help solving a problem I have been having with my 2001 2.5TDI T4.
The problem is that my dash clocks do not work.
At the moment the speedo doesn't work, fuel gauge kinda works but when I turn corners or if I'm below a quarter of a tank the fuel light goes on and off with that annoying beep that means no fuel, whilst I drive the fuel gauge is going up and down.
Also the mileage does not register at all (trip mileage and total mileage).
When I bought the van last year the was an intermittent problem with the speedo not working but it didn't happen very often, and there were no other problems with it. Until I got an auto electrician to connect my leisure battery, a week or so after he fitted it my main battery was flat and ever since I have had the issue with the clocks.
Today I fitted another set thinking that my existing clocks were the issue but the problem are still there, I am totally stuck with what to do. Has anyone ever had this problem and what did you do to solve it.
I will be calling another auto electrician to check it out but if anyone can help shed light on what may be the problem before I get the electrician out that would be much appreciated, plus the beeping is driving me flippin nuts.
Abbey
Abbey
