Hi there that depends on the clocks you have in your t4 ? if you have a rev counter ! also the digital clock and oddometer are different on the pin set up on the back but there are many diff types of clocks that with a little time can be wired in to fit . vw passat clocks and corrado etc . hope this helps a little and there are lots of peeps on here that have done speedo swaps.T: Good luck A:
