I have 5x112 17inch 7 spoke audi a4 alloys fitted to my '52 plate T4 and need spigot rings to stop the vibration but I'm confused as to which size I need. I'm told the hub is 57.1mm and the alloy centre bore is 57.1mm?!? Any help is much appreciated
Full of Cr*p....
" hub is 57.1mm and the alloy centre bore is 57.1mm"
You don't need spigot rings..in fact, you CAN'T fit them!
Vibration could be due to the fact that Audi A4 rims ARE NOT SUITABLE FOR A VW T4 VAN!!!!!!!.
Check the load rating....
Curb Weight 1170 – 1514 kg.....that's LOWER than MY front axle rating!!!!!
Basically means, you're using wheels that have LESS THAN HALF the weight rating for your van!
Good luck with informing your insurance company of that.:eek:
