evening.
fitted a 100a split charge relay,positive in from starter battery out to leisure battery,small connector to earth on starter battery,small connector which feeds from alternator.
when the alternator feed is connected and ignition switched on the relay buzzes and battery warning light stays on when engine is running,even when revved?no charge is being put into starter battery or leisure either when this wire is connected?
once this wire is dissconnected battery light stays off,no buzzing and alternator charges normally?(14v)
both batteries new,alternator 18month old?
unlucky enough to have a faulty relay? :*
