Anyone had a split charger unit die on them?
For some reason mine isnt chucking out any voltage! Fitted about 3 yrs ago, bouth from uspex (i think)
Are you getting a feed onto the relay terminals which makes it switch?
Have you got a voltage on the incoming side of the relay (big wire coming in) from that to earth 13.8Vdc when engine is running and 12vdc when engine is not running?
Same on the outgoing side between big wire coming out and earth, but no 12vdc when engine is not running, but 13.8vdc whent he engine is running.
Sorry if these sounds like stoopid questions, but I assume little knowledge and work from there.
