Hey
Anyone know if I can use a 12V 140amp Durite 0-727-33 voltage sensitive/intelligent Split Charge Relay to power/charge x2 batteries at the same time by connecting them both to the VSR?
I have a 110ah leisure bat and also a 30ah bat from a golf cart that I want to use to power my 12v TV and run the telly separate from the main leisure battery.
I tend to fall asleep with the telly on and don’t want to draw power from the main battery while I’m asleep so had the idea of using a smaller battery just for the tv.
My mind tells me this would work as I’m just splitting the output from the vsr ...but as the batteries are different sizes / aH would it cause anything weird to happen ‘electrically ‘ wise?
Charge/load balance issues?
If so...I’ll just install x2 vsr’s but if I can run them both of one vsr be great
Ant T:
Ant T:
