Hello all
First post so forgive my ignorance! :ILU:
Considering installing a second battery with a split charge system - questions are:
If I want my current van stereo and amp set-up to run off the leisure/second battery what do I need to do? Presumably I need to re-connect to new battery?
Aside from the battery and the split charge pack what else do I need to be able to install a double socket in the rear to run a TV and Playstation 3?
Hoping to be a regular contributor as I finish converting my T4 and using it to travel
Remove the fuse for the stereo from the van fuse box. Run a fused wire from the leisure battery to the bottom half of the fuse socket. Your stereo will now be powered by the leisure battery.
Full of Cr*p....
Are you sure?
What about the switched live connection from the ignitipn??
OP...Contact upspex or Hoovie on here.....they can sort you out for both of your questions.
