Hi all,
hope someone out there has an answer to my problem?
have a load squealing coming from the steering/crank pulley area and a very slight wobble on crank pulley and oil leak from unknown point around the same area are they all linked and what will fix the problem as tried WD40 on pulleys and stop for a while and starts again also tried belt dressing and had the same response need to sort it as squealing load, load, load and doing my head in.:(
Any help or advice would be great as new to this.
thank you in advance for your helpT:
