hi all when i start the van it makes a screeching noise,then when i rev it and rev it again the noise goes any ides?its a 1.9td cheers matt
mine does the same mate its well inbarrasing ill keep an eye on the answer for this.
if its the Power steering belt that needs adjusting, this if done by changing the shims around from memory??
when you start it from cold,let the belts squeal. DON'T rev it.. quick squirt of WD40 on the alternator belt. if the squeal stops. thats the belt that needs adjusting. if it doesn't then squirt the Power steering belt.. if it stops now.. theres the problem:D
both are easy enough to adjust. ;)
