Anyone got any idea on this problem i have with my 1.9td 98, starter motor.
Van is dead on turn of key, Battery reading 13+ on volt meter, battery negative to starter solenoid switch i have no reading, ie no power.
Thinking fuse or relay, unfortunately i have no wireing diagrams etc, anyone know if it is a fuse/relay problem and were i would find it to check.
If not any ideas what problem could be.
T:
If you've got no power to your solenoid when the key is in the cranking position, then it sounds very much like your ignition switch needs replacing. How did you get that reading? It needs two people - one with a multimeter and one to crank… just checking you're 100% certain there's no power when cranking.
"It needs two people - one with a multimeter and one to crank… "
No it doesn't, leads clipped to battery.. meter on wiper blade, (screen facing in of course).
