Hi all im having trouble with start up ie it starts but not like it should sometimes takes a couple of trys. Its been to the garage its the glow plugs definate as some were shot......not the glow plugs still happening ah its the injectors ive now had them all reconditioned.....not the injectors still happening....whats more it now randomly cuts out dead in the water .ive changed relay 109 no effect any ideas cos i cant afford another trip to the garage to not fix the problem im thinking fuel either leaking back to tank or air in system
what van?
if t4 then look at the fuel pipes / filter AND the 'thermo-valve' on top of the fuel-filter (the return line connection plastic fitting on the filter)
Rich.
