Not sure if this should be in engine section or not :*
I have a 1997 t4 lwb 2.5 and when you turn ignitin switch nothing happens some times , You can hear relay click but nothing else, Dash lights dont dim or nothing but if you keep trying it will turn engine over after a few goes
any ideas what to check
colin
More likely to be the red/black wire connection at the starter solenoid. Take it off and clean it. (spade connector).
