1 - 12 of 12 Posts
Can someone tell me why I am fighting with the steering wheel to keep the van in a straight line. I have replaced the power steering pump recently but am due to replace the ball joints? Is this the answer ir is it the steering rack?
Please help
Before I drove 2400 miles in the last 2 wks I was advised that it was within tolerance by the garage, if that helps
I won't go into the moan, but had a similar issue with serious play on the steering wheel and being told it was the steering boss I'd fitted with the after market steering wheel by the specialist garage - it was the track rod ends.
I only realised when I checked the tyres on a routine 'around the Velle' and noticed one had worn badly, suddenly and unevenly and went to get a new one. Tyre fitters were a bit WTF and that's when I realised how lucky I'd been to stay on the road!!
Just a thought and easy thing for you to double check T:
Do you have big alloys ?, big alloys suffer from this,as theres a lot of tyre on the road so follows all the cambers/curves.Its worse on the inside lane of motorways, as all the hgv's running on the inside lane, have left sunken 2 x tram lines,that throw the van all over the place,feels a bit like a puncture :*
As above, I've got 17" 8j alloys on the van and suffer with the ruts on the road pulling the van all over the place. When I put the steels back on, the problem disappears. Will be looking for different alloys, narrower ones. But I also have a track rod end which needs replacing, which might explain why the van tends to pull more to one side than the other.
Are you able to find a nice stretch of straight, flat, decent road and see if it drives straight and brakes straight?
Pay attention to any minute play in the lower wishbone bushes as any play there will let the wheel be dragged around significantly by grooves in the road.
Hi, Suffered for 3 years with pulling to the left, been to 3 "specialists" to rectify but always the same, my Tyre Fitters (Hot Hatch Corner in Longton, Stoke-on-Trent) recommended QuikFit in Hanley, £49 later she has never driven so nicely, I can now take my hands off the steering wheel!! She still tracks a little with road camber (left and right) and I can feel my steering wheel is loads more balanced now. Hopefully I won't need new tyres every 5000 miles now!!
QuikFit will check for FREE and are OPEN ON SUNDAYS so it's a massive bonus for my to be able to 'pop-in' on a Sunday. Have had track rod ends and ball joints etc replaced and this has now finally sorted it out (and I even let the wife drive her now!!)
Chuzz
£49 later she has never driven so nicely...
Any idea what they did? I've nothing against Quickfit personally but I know a lot of people here have, and the chances are if they did it for £49 you could do it yourself for a tenner.
I just noticed a few weeks ago that mine's started pulling a little to the left too :(
1 - 12 of 12 Posts
