1 - 10 of 10 Posts
Hi
I was looking at a T4 today with the intention of buying, one thing I noticed was a bit of play with the steering wheel not the steering its self can anyone advice.
Thank You
Scottish Motorsport
Is it an aftermarket steering wheel ? Ive got a momo on mine off a mk 3 golf that sits on a polo spline adaptor and needs tightened up, if original steering wheel i havent a clue.......:*
Had this on 99 velle (no airbag). Simple to sort. Get the steering wheel off and remove controls, you should then see a plastic collar, then a thin compression washer then a big spring. Stick a bit of pipe over the column and tap the compression washer down onto the spring (take collar off first). Should tighten it all up. replace all the gubbins and stick the wheel back on. Worked a treat for me.T:
Discussion Starter · #8 ·
Thank you for your help first time owning a T4 I have had a Transit in the passed that I converted to a day van but new to the VW T4.
Took the van for its first trip today
1 - 10 of 10 Posts
