Hi,am confused,want :*to fit new steering wheel as mine is ,which one will fit ,09 t5 has 4 spoke ,airbag,horn only,will 5.1 wheel fit,thanks.
Hi I have a 54 plate T5. My steering wheels needs replacing. Will the wheel pictured above fit? Also is it difficult especially with the airbag connection and is it safe to buy a 2nd hand one? Are there any special tools required and is it easy to align it centrally so that the steering doesn't go out of alignment?
I've got a 2014 Polo flat bottom wheel on my 54 plate T5. Wheel bolts straight on. All you need to do is solder the airbag connector off the new airbag loom onto your original loom.
Pretty easy really
