I've got a t4 caravelle 2001.
The horn has been going off when I don't want it to. I took the wheel off and there's a washer on top of the spring. It's very misshapen. What should it look like?
The spring is also loose - in that you can remove it easily and put it back, but looking at other threads it seems that maybe it shouldn't be loose? And I wonder if it's the misshapen washer that's causing the horn to play up?
On mine (I dont know what model u have) . the horn push is removable on th wheel , and has contacts that are normally kept apart with springs .. if any , or all of these are missing , it may allow th horn to operate ad-hoc ...
ha ssimilar with mine when turning the wheel horn would go. this was after installing another stalk, it was the 3 screws that hold the stalk in place just needed tightened up a little more they were contacting off of the screw heads.
yep it was the bottom one that was the offender i hadnt tightened it enough after fitting another stalk. whats going on with the insulating tape? i'd check that out
