HI does any 1 know if any other standard vw steering wheels will fit my 98 t4 1.9
Eg golf or passat ??????,
Hi it has not got an airbag so could put any wheel on, was hoping th:)ere would be 1 I could just swap it for with out to much messing
I've got a 97 caravelle, and I'm putting an early mk3 golf gti/vr6 non airbag wheel on it. Its pretty straightforward, I'll be putting up a How-to on the forum later today. You'll need the steering wheel and horn push, the horn slip ring if its not attached to the wheel (about a tenner from vw), and a spline adapter which you can either get secondhand for pennies or new for a tenner. The only fiddly bit is the need to saw a bit off the adapter to get its length down to allow the horn ring and indicator self canceller to engage. You can pick up vr6 wheels for about £30 from a breaker.T:
Good info!
One question though; I am restricted by TüV what modification is conserned which to some extend is OK
TüV is conserned with the size of the steering wheel fitted. On a van I do not thik they accept anything below Ø360mm regardless of servo or not (I am sure I will be corrected on this figure if it is way out of bounce, was applicable at least 12 month ago)
I U please could post the actual size of the wheels U fit, their origin, mods needed for all to work (as above) & how U cope with the actual size, that would be really a huge benefit to allT:
