1 - 9 of 9 Posts
I bought some LED strips at van fest and now have the time to fit them. I've cut the holes but is sikaflex the best thing to stick metal (aluminium I think) to the plastic side step?
221 or 512 will be OK, but to be honest, you may struggle to find it in a DIY store.
There are however plenty of other polyeurethane adhesive/ sealants out there such as tigerseal etc. These may be easier to come by in a motor accessory shop etc.
If you do use something like this, bear in mind it wont come out easy if required later on.
If its not in an area where its going to get wet or knocked, then even a light bead of scilicone may do the trick.
1 - 9 of 9 Posts
